D21_Destroyer »
https://forums.nicoclub.com/d21-destroyer-u80687.html
Tue May 06, 2008 1:15 pm
I would really appreciate any insight into my problem as it is debilitating my truck. I have a 1992 Nissan Hardbody RWD, KA24E, 5 Speed manual.I recently changed my sparkplugs and noticed the engine wasn't running well afterwards. I checked the resistance through the plugs and found one that had about 25 times higher resistance than the others. I switched that out for a good one but I'm still having problems with cylinders missing. I can't tell if it's the same cylinder that misses every time, or if they're switching. The problem is also inconsistant. i find the problem doesn't occur over 5000RPM and only occurs when the engine is under load, the rest of the time it may or may not misfire.I've checked the wires and plugs, which are all good. The distributor looked fine and the problem is inconsistant so I don't think thats the problem. The local auto parts store has suggested that it may be injectors, the Throttle Position Sensor, or the fuel pressure regulator. I tried adjusting the TPS but am not sure i was doing it right, as i measured 0 through it no matter how it was adjusted.
Any ideas as to why my engine is screwing up would be appreciated, i need this truck running.
