Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Wed Jan 21, 2009 5:26 am
The 4x4 axle will be wider than what you have, so if that doesn't bother you, go for it. The 4x4 axles will also be geared considerably lower, meaning higher engine rpm with the same sized tires.
Nissan LSDs are OK in the D21 years; they're near worthless in the D22 years, and if you're looking for the performance of a locker, I think you'll be disappointed.
The H190 axle, which I assume you have, is OK in stock configuration, but doesn't lend itself well to modding. It lacks the adjustment of its bigger H233B brother when regearing and installing lockers. I do think a mechanical detroit locker is available for that axle still, but that's it. The larger C200 and H233B axles will accept an ARB air locker, but those are expensive.
Another option is to source an H233B axle from a 4x4 '95 or older pickup with an open diff. Those have the 4 pinion carrier and will accept a lockrite rear locker, which is half the cost of an ARB. Again, you're talking a bit wider axle here, and you'll also need the flange end of the driveshaft from the larger axle because the bolt pattern is larger. The same Ujoint can be used.
4x4s were also spring over axle, so the spring perches would need to be cut and rewelded for a spring under configuration.
There were V6 2wd hardbodies, but they're pretty rare. I'm not positive on this, but I think they came with a larger rear axle, perhaps a C200 or maybe even the H233B. That would be a direct bolt in replacement if you can find one.
