Good morning all, I know this has been posted before and I have read through varius articles but I feel I need further assistance.
Yesterday in a parking lot my car started steaming/smoking and overheated. Basically its the "fans not turning on" problem. Below is where Im at with this.
* No collant leaks (I assume the reservoiur shot out the coolant that made it smoke)* I replaced the 4-pin relay and no luck. The other was $40 and they were out of stock...* Did the coolant recently and was carefull to get the air out of the system. * Fuse is fine* Fans will NOT turn on when I start the air conditioner.
I would just wire up a switch on a power lead to controll it manually till I can really afford a repair but I am trying to sell this thing soon.
I have read that it could be the Coolant Temprature Switch. Well everyone says that it's under the Oil Filter but for the life of me I can't see or feel it. Do I have to take the oil filter off to get at it? I dont see an easy way of accessing it from underneath either. Maybe I was reading about another year?Mine is a 1992 G20.
Thanks for any advice you all could offer!
