Q451990 »
https://forums.nicoclub.com/q451990-u142.html
Fri Dec 14, 2007 5:45 am
Ok... just for fun (I know, I have a warped sense of "fun") I called the number I found for Bose. 1-800-231-2673, option 4.
Their current pricing structure is:Rebuild Amp Only: $75.00eaRebuild Entire Assembly (Replace speaker too): $140eaAnd if you have all four assemblies done, the 4th one is free. So $420 for all four new speakers and amps.
Also keep in mind that your rears were covered in a recall, so it would be worth checking with the dealership to see if that was performed. I believe it was all 1991 and 1992 Q45s that had the recall. The VIN Range for the 1992 models included is JNKNG01**NM200001 - 219999. If by some chance that recall wasn't done on your car yet you can get those amps replaced at no charge.
Good luck!
Heath
