I have a 1992 Nissan D21 with a KA24e engine with ~ 142K miles.
Current Symptoms:
- Low compression on #2 & #3 cylinders (~ 30+ psi).
- Compression is fine on #1 & #4 cylinders (~165 psi).
- No difference in compression between wet & dry compression tests (indicating “problem” is on upper/valve side of pistons).
- I am pretty sure low compression is driven by open/damaged exhaust valves as you can “hear” it through exhaust when under load
- Rough idle and low power (of course)
- From what I understand, I am now faced with replacing the hydraulic lifters and possibly valves as well…How likely is the issue with ONLY the hydraulic lifters and not the valves?
- Should I plan on replacing both (lifters and valves)? If the valves are also replaced, will it require any machining on the head?
- Anything else I should do or check? Suggestions or advice?
- Are there any specific posts or videos I should reference that will help me to attempt such a project?
- Is it worth it? Any idea of costs?
Background:
Prior to my current situation, I experienced a very loud “knocking” which I assumed were some sticky lifters. I used Marvel mystery oil and the knocking eventually subsided, so I assumed I had a sticky lifter (or 2) which was corrected with the oil treatment.
I have replaced timing chain, guides, seals, etc. as well as the harmonic balancer/pulley (because I damaged the original one during removal) at ~107K miles. The chain guide later "came loose " (I heard the rattle) so I had to re-install it again at ~133K when I noticed the cam had jumped a tooth. I am thinking this might even be part of the root cause of my current problems? Who knows...
The truck belonged to my pop who passed away ~16 years ago, so there are some sentimental strings attached to keeping it running as long as possible. It is nice to have around for home projects and to haul stuff, but it isn’t a critical vehicle so I can take my time and work on it without having to rush. On the other hand, I want to be reasonable about what it will take (in both time and $s) to keep the truck running. If it is time to let the truck go, then I can do that (albeit reluctantly).
Sorry for the long post...and thanks again in advance for any help or advice.
