evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Oct 04, 2006 6:24 pm
my TT had a bad vibration under braking, I replaced rotors and pads on all 4 corners and it still vibrated under braking, when I replaced the tires the shop found one wheel had a "Hop" basically bent in a non visable way untill it was spinning on the machine, this helped a lot, but the pulsation was still there under hard braking, I finally replaced the steering rack bushings and now handles perfectly, the wheel ballance is a cheap item to check and can tell you if you have a bad wheel, the rack bushing would be my next guess if the ballancing doesn't solve anything
