onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Fri Dec 17, 2004 12:17 pm
Hmmm, did you purchase the nissan harness adapter? This plugs into the 2 plugs from the car's chassis and is marked w/ all the labels (i.e. power, stereo left +, illumination, etc), then you use that to connect to the stereo head unit.
In any case, the easiest way to do this is to use a multimeter (or a test light, but use that at your own risk ). Just probe to make sure the power on and constant 12v is powered correctly. Then you should be able to get your head unit to come on at the least. Also, check the fuse on the unit if that doesn't work.
The illumination has to do w/ either when you turn the headlights on or just the backlight of the display.
The dimmer will get brighter/darker along w/ the rest of the lights on the cluster and climate control in your car by your car's dimmer switch.
Those can definitely be hooked up, I've done that on my car.
Do you have the manual for your headunit? or can you d/l a manual? That usually contains a diagram for the stereo side w/ the colors. Then you match up w/ the chassis side and you'll be set.
and GET A MULTIMETER!!!! - you'll need that for many things, so it pays for itself rather quickly.
Also, I just noticed you posted this in technical, I know you'll get some real expert advice if this is linked to or posted in the Audio section.
Hope that helps a lil.
