1968cougar »
https://forums.nicoclub.com/1968cougar-u39806.html
Wed May 24, 2006 5:53 am
I've got an interesting issue that just cropped up. To start it is a 92 240sx SE, power steering, stock suspension, no sway bars, hicas still functioning, aftermarket speedylite 7 wheels 17" on 205/40 17 and ABS brakes. the speedies are from the factory hub centric I didn't have to buy the centrics. Suspension is still all original as far as I know. Car and chassis only has 80k. There is a slight steering wheel vibration at 45-55 but it appears to be wear and not balance. Clears up past that speed.When I start braking my steering wheel shifts about an inch to the right and the steering goes left a bit. This only happens during braking. I ran my local flyover at 90 and steering is solid as ever. If I start depressing the brakes a tad the steering goes left and the wheel shifts right. This is NOT a brake pull. I do not have to hold the wheel to correct. It is a complete shift of the steerings center.
When I come up to a stop light and stop I can feel the wheel shift and it will be slightly right when I'm stopped. It is the oddest thing. Any ideas?Something worn? Loose rack?
Thanks in advance!
Robert
