desense »
https://forums.nicoclub.com/desense-u42466.html
Fri Jun 23, 2006 7:15 pm
Car just refused to start on my lunch break the other day. After about 15 minutes, it finally sputtered to life. After work, started fine. Next day on lunch, same thing happened. Today, it won't start at all.It is cranking fine, just not starting. I tested plug wires and they are fine. Spark to the distributor is fine as well.
I changed the fuel filter, Coil, ignition module. Fuel is fine, lines are pressured so I don't think it is a fuel problem. Cap & rotor maybe? Plugs?
I am out of ideas other than that and I don't have money right now to throw at it until I find the problem. Anybody have any pretty solid ideas of the possible cause?
