rpd240 wrote:Don't want to thread jack but I have a rattling sound coming from the front of my 1991 240sx motor during idle and mid rang RPMs. Not sure what it could be
In your case, the timing chain guide(s) are most likely wiped out. Also if the motor has a top chain guide, it may be loose.
There was a Nissan technical bulletin issued that said on the DOHC the top chain guide and upper chain side guide can be removed. One or both of those guides could be making the noise. Both guides can be removed fairly easily without removing the both timing cover; only the top timing cover needs to be removed.
If you've done the above and the noise is still there, then the lower chain guide may be worn.
