1992 240sx SE EMISSIONS FAILED
boostdet
Car: 240sx 92
**** i dont know guys
NO is reading at - 2009 and it needs to be at like 945CO is reading at - .77 it needs to be .73
any suggestions?
Catalytic Converter is one thing i had in mind
the car seems to need oil change and basically all in all tune up -- other than that i just dont know
as far as mods
just an intake
boostdet
Car: 240sx 92
got the cat changed
so how do i work on the EGR valve?
or...what do i add to the fuel..to pass!!
Ii3edus
Car: 92 s13
i had the same issues. changed my cat. and added fuel additives just made things worse. for me it took a $50 timing light gun and 10mm socket. adjusted the timing which was at like 10 degrees instead of 20. problem solved. for me anyways
LordOfTheMiasma
Car: s-13 hicas sr20det 240sx
jus slip the guy testing you some extra money, i live in wonderful florida where there are no emission laws but i have seen many people talking here on nico about how they pay there way through emissions... jus gotta know someone..lol
sleepyRPS13
Car: to sleep
its not just the egr. if you go slightly lean it can cause the nox to go up up!
-overheated engine
-lean air/fuel mixture
-vacuum leaks
-overadvanced ignition timing
-defective egr
anything that can cause higher combustion temp!
