darklynoon »
https://forums.nicoclub.com/darklynoon-u34191.html
Tue Jun 27, 2006 7:19 pm
ok, for the knocking, definitely your guides, but these are important, but only if they break off. can seriously thrash your sh*t. there is an excellent article floating around, dont have the link at the moment tho for the oil, if its the valves, it will start to lessen as you drive, but if you leave your car idling for a little bit, 10 minutes, maybe less, then get in it...major plumes of blue smoke. easiest way to see it is to get in and go in reverse, not forwards, if its noticeably worse, this is the begining of needing a valve job..or a head job (dont look at me, but i got a younger sister tho i pimp out sometimes...j/k) to check your ring seals, do a leak down test, im not gonna explain how, find it in any haynes or chiltons. if its your pcv valve, i believe u tend to have oil majically appear in you air filter, its been a while tho, that may only be from your aic doohicky (the square black plastic box with a hose that goes to your filter box
for the radio, besides the fuses, make sure the antenna is plugged in. no antenna, radio no turn on. remember you need an adapter for nissan's rediculous dual antenna setup. get it at pep boys, like $5-10 bux. also, make sure the amp wire (the light blue one that ist for the power antenna) that is comin from the radio, is attached to a power source. for most radios, u can actually splice it in with the power antenna wire. it can get trickier, but repost if u need that info.
for exhaust, just replace what you need with oem, but get a free flow, or high flow cat and go to midas to weld it in, the will do it for under $100 usually, and one of the few places that will install 3rd party aftermarket parts. P.S. if u pay cash, with no receipt, it has a tendency to be cheaper there
and you already heard the answer for the seatbelts, and cant help u with the ac, check the fuses, and engine compartment relays
NOW SOMEONE PLEASE HELP ME WITH INFO ON REPLACING MY HIGH PRESSURE POWER STEERING HOSE!!!!!
