1992 240sx manual transmission problem
beatd
Car: 92 KA-T 240SX and 08 Fit Sport
can someone help me determine the problem so i can figure out how much its going to cost before i take it to the mechanic. heres what is going with the transmission.
it goes into 1st gear fine but when i try to go into 2nd from first gear it will grind but i can still shift it and it would stay in place. 3rd, 4th, and reverse is fine, as for the 5th gear i have to told it into place just to drive it won't stay shifted.
thats pretty much the problem sorry i tried my best to describe whats going on any help would be great thanks.
navysnail
1st gear doesn't have a synchro, so unless you rev match first, it will grind unless you come to a complete stop or close to one.
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
The 1st/2nd gear synchronizer is most likely worn. The 5th gear synchronizer may also be worn or else the shift forks may be worn.
