Neejay wrote:Did you ever find a fix for code 21? I just started throwing this code after putting my intake manifold back on.
Yes, I did fix this. This was a problem with my injectors. When I took my intake manifold off, all of them magically died so I had to replace them and my car started up fine.
I checked my injectors by pulling the fuel rail out and unpluging the ignition coil. (You don't have the un-plug the ignition coil but I did it to be sure the car had no chance of starting while the injectors were removed.) Afterwards I tried to start the engine to see if the injectors sprayed fuel or not.
If you end up replacing the Injectors, get them on ebay from this guy. He gives a one year warranty on his injectors and they're dirt cheap.
If the injectors aren't to blame, I would check the ignition coil and test for spark because you can't have spark plus fuel and no start. (In most cases anyways.)
