Tims_240 »
https://forums.nicoclub.com/tims-240-u19154.html
Sat Dec 08, 2007 6:16 am
I did an engine swap in my 240 and now I'm having problems with my Mafs. I hooked up a nissan consult to my car and when I put the key in the "on" position the mafs reads 5V which is max voltage. When I start the car the sensor still reads 5V, and the car stumbles alot, but will still hold an idle. When I unplug the mafs the engine smooths out and holds a steady idle of about 1100 rpm. Which would lead me to believe that the mafs is bad, however I have taken a mafs off of a running 240sx and it does the same thing. I have tried grounding the mafs wire to the chassis and the idle gets worse. I have tried another used ecu too and the car acted the same way. The ecu only throws code 12 which is the mafs, and no other codes. I am stumped but am hoping someone could help me out.
-Tim
