1992 240SX ignition problem
Gibrio
Car: 1992 240SX Nissan (standard transmission)
1992 240SX Nissan (standard transmission) ignition problem
I have replaced: -battery cables and ensured proper ground -starter motor (had it tested before installation) -the ignition switch assembly (got a new key and everything) -starter/ignition relay switch and tested the battery, yet the the engine still turns only about 20% of the time when I try to start the car. Aside from replacing the clutch relays, (meaning spending more money) does anyone have any other suggestions?
Thanks, Gibrio
MaximA32
I see you haven't tested the alternator. I would check the output of the alternator while the car is running. It should be somewhere around 14v while running. If it's not, you've got a bad alternator.
Gibrio
I have not tested the alternator because the battery not only maintained a charge but, when tested it was not discharged. Would the output affect starting the car eventhought the battery is charged? Regardless, I will test the voltage and appreciate the input dude.Thanks,Gino
vancouverbc
Car: 1991 240sx
look up starter in tutorial link in my signature.
ignition relay doesnt affect engine turning over. interlock relay(by battery) does but replacing parts is waste of money.
s13_240_rb20
Car: 1990 240sx RB20DET
Here is something free to look into (without much effort also).
My fiance's oldsmobile has had a problem with starting for almost a year now. The symptom: engine would not turn over OR turnover was delayed a few seconds after key turn.
The problem: the wire plug at the ignition switch (the electrical part BEHIND THE IGNITION KEY LOCK) has a loose wire. I took off the steering column "collar" (the plastic shroud) and jiggled the wire harness while turning the key....started right up. Since then I have left the collar off because I need to give it the occassional little jiggle..
--TJ
Gibrio
I sincerely appreciate the resources eventhough it means I have a lot of studying to do (my head hurts when I think man - I kid).EXCELLENT information kind sirGino
Gibrio
I will definitely give that idea a try and thanks TJGino
