boriquaS13 wrote:Does the missfire seem like only one cyl. is the problem or does it feel like it may be random cylinders. Could you possibly do a cyl. balance test when its occuring? How does your car idle when warm? Does it sound like its backfireing through the intake when its happening (maybe leaning out cold)?
It feels like random cylinders. I could try a ballance test: I have a CONSULT interface that I can do that through (though it's only really usefull for turning off individual cylinders, not a *true* factory ballance test). May I can narrow it down to one cylinder.
When warmed up, the idle is OK, although about ever 20-30seconds I hear a slight miss (I hear it because of the 2.5" exhaust). If I'm watching the engine closesly at idle I can see it 'twitch' (for lack of better terms) when it does this.
It's certainly not a backfire, and I haven't honestly listened to it while in the engine bay.
Thanks for your help!
Oh, worth mentioning: I did a datalog of the ECU while trying to hold 2000rpm on a cold start. Nothing really jumped out, the RPM obviously was bumpy, along with MAF and injector times as well(to compensate I presumed).
