1992 240SX Convertible: Removal Of Blower Unit Drawing???
240ROCKER
Does anyone have a picture detailing how the blower unit assembly is mounted under the dash on the passenger side? I have the service manual, but it isn't detailed enough!
Thanks!
240ROCKER
NISTECH
are you trying to remove the whole housing or just the motor? the motor simply drops out the bottom by removing three screws around it.
240ROCKER
I'm trying to remove the whole blower assembly as I was able to remove the lower half of the housing after loosening some screws on the heater core assy. When I removed the blower housing I had to remove about 7 clips that hold the top and bottom of the blower assy. together. In order to put all the clips back on, I need to remove the whole blower assy. It looks to a huge job to remove the whole blower assy. that is why I was wanting some sort of diagram or illustration showing me how this assy. is mounted in the dash!Thanks for any info you can provide!
240ROCKER
NISTECH
there should be 3 or 4 screws holding it into the car but I believe you need to pull the dash to gain access and be able to remove it completely as well as the A/C evap unit.
