x240xdrifter »
https://forums.nicoclub.com/x240xdrifter-u22577.html
Thu Jul 06, 2006 8:10 pm
power is a big thing in drifting but suspension is bigger, first off you need a LSD. your best bet depending on your driving techniques is a 2-way or 1.5 way lsd. also you need tie rod ends, adjustable camber kits, tension rods, adjustable control arms, toe links and so on, and I reccomend coilovers over your springs and strut set-up. its more adjustable, you can adjust your spring preload, rebound and compression as well your ride height. Also you totally neglected brakes and tires, you want a strong brake pad and fluid to handle high temps and bite to the rotor not to mention stainless steel brake lines, I mean your brakes are going to take most of the abuse. also you want a good tire combo, sure when your learning you want crappy ties so its easier to slide, but once you get your groove its essential to have tires that grip when you want it, drifting is not about just going sideways out of control, you want to teater on the edge, and you need good gripping tires to be able control when you want the car to come back but this is all for a full out drift attack machine, in all pracitcality, you only need a lsd, good brake pads/lines and tires. good luck on your project, remember power isn't everything, its balance that makes the car succeed. research and learn the pyshics of drifting, it will help tuning and set-up easier
