boryan »
https://forums.nicoclub.com/boryan-u31583.html
Mon Apr 24, 2006 5:23 am
This is the first engine rebuild I'm doing, but I read up a bit on it, but the reason I called the chain guide a tensioner was because I was writting the post at 3:00AM, sorry.
So, I have the head off but I haven't been able to take the springs out yet. Do you know what tool I could use to do that? Should I just check the valve head diameter with a caliper to check for wear?
Now for the cylinders, When I took the pistons out there appeared to be no significant ridge, so I was just planning on honing them. But how would I check for the piston-to-wall clearance? Should I just stick a feeler gauge between a piston and wall?
I checked the cylinder head for distortion and it only had .005mm of play. I also checked if the main journals were lined and they also only had .005mm of play. However when I took the rods off the crank shaft, some of the bearings were cracked and came off in two pieces. Would a significant problem be the cause of that?
Thanks a lot for you advice rogoman
Modified by boryan at 12:54 PM 4/24/2006
Modified by boryan at 5:28 PM 4/24/2006
