1992 240sx all parking lights stay on
LOL_JDM
hey guys, i have a couple issues with my 240sx coupe...but the main one bugging me now is my parking lights are staying on ONLY WHEN i unplug fuse number 18 under the dash....there has to be no fuse there...if i put a fuse in, then they stay on no matter what unless of course i unplug the battery...
when the fuse is out everything seemingly works fine but im not 100 percent sure on that as i got the car, drove it around the block a couple times, then tore the motor out to rebuild for ka-t...motor is almost done now and i need to get the wiring squared away...
i know this has to be a common problem because a few years ago a buddy of mine had a coupe that the brake lights completely stopped working on...
if anyone has any experience or know-how please feel free to share! i would greatly appreciate it!!
thanks in advance!!
-Jared
LOL_JDM
anyone got any ideas?
LOL_JDM
you guyyyyyyyyys?!
LOL_JDM
still need help...this is kicking my a** and i have no clue where to even start...the problem has to be in the map light circuit (the fuse that i pull to make everything work normally...except obviously the interior lights)
localtechyguy
Car: 1988 240sx
LOL_JDM
im thinking the problem may be with the wires that are cut on the dash harness....the harness for the radio had a cut wire or 2...still cant figure out where a couple other wires go to...some are blue others are red with orage tracers or vice versa...not sure but will get exact colors tomorro and going to look at another unmolested harness in the junkyard hopefully...still any help is appreciated!
LOL_JDM
motor is almost ready to go in..gonna try to fix whats cut and f*** it if it doesnt fix the problem...will just have someone fix it later or ill fix it later when i have the damn thing running....no sense paying insurance and having a tag for it if its gonna sit around with the dash off waiting on a response to this thread that obviously is never going to come
c72c
Car: 97 S14 n/a
if it's an aftermarket stereo check the wiring, i had this same problem on 3 of my cars a few years ago, took a while before i realized it happened after i installed a new stereo. pull the stereo out, disconnect all the wires that are spliced, check if they stay on, if they turn off, you're done, just rewire the stereo right.
if they don't turn off after the splices are seperated, start following the harness, you probly have a short somewhere.
LOL_JDM
yea it seems like the stereo as that is where wires are cut...i know the black/red wire for the input to the head unit was cut i put that 1 back together...theres also a red/yellow wire and a few blue wires cut
c72c
Car: 97 S14 n/a
yea, best bet, disconnect all the wires and start over. pin point which wires are which, if you don't know, start at the speaker. see which speakers have which color wires (if they're still stock) and that'll get 8 wires outta your way. then you should have your hot, ign, ground, ant, and maybe a few others. try to refrain from putting the hot and ign together to the two for the power to the stereo, that'll causes problems sometimes. also another thing to check when you re connect the stereo, with the stereo on, turn the parking lights on to make sure you still don't have crossed wires. did that too, stereo would work till i turned the lights on, then it would turn off. haha.
LOL_JDM
PROBLEM FIXED!!!!! finally my friend came over and rewired my f**ked up car! it was the stereo wiring that the idiot somewhere down the line had attempted and failed epicly to rewire...FINALLY lights that work right! and the KA is almost ready to be put back in...hopefully ill be driving this car soon! wow! thanks for the help c72c!
