1992 240sx - Adjusted timing, now it wont start
evlzer0
I had a slight timing issue with my car for a little while now, more of an annoyance than anything. I tried to fix it by adjusting my timing a few degrees and it just got worse. So i started from scratch and reset the timing to TDC as per this posts instructions.zerothread?id=161707
I had previously set my timing without problems using this procedure. The Spark Plugs are wet with fuel. I have also tested each plug and they all get good spark. My battery has started to die now so i have to get a charger before i can work at this some more. I dont have a timing light available to me either. I have even tried setting the timing to where it was when the car worked, no change. When i turn the key It starts to turn over but there is no combustion. Or, there will be one 'pop' then nothing. Any ideas on how i can correct this? I ran a search but found only a few related articles that were slightly different problems, and no answers for my situation.
180fan
Car: 89 fastback
Probably 180 degrees off. Pull and try again.
evlzer0
Allright, so have the rotor in line with the #4 plug instead?
evlzer0
Got it fixed, had to set it about 5 different times before it turned over and started. Thanks.
