Like I said, many other manufacturers have run that way. Nissan may not have, but when the transmission harness was unplugged from my 1992 auto it shifted through all the gears. Sure the shifts were harsh and always at higher rpms, but it still shifted. 95 Ford F-350, same deal.NISTECH wrote:I dont know where that info came from yellow jacket but it is absolutly false information. All nissan automatic trans built at least starting in the late 80's use and electronic revolution sensor to determine shift points. This sensor replaced the old governor. If you unplug the electrical harness to the trans it will go into third gear and stay there. That is done so you can at least get the car to a shop to get fixed. It will NEVER shift with out shift solonoid a and b directing the hydrolic pressure to the appropriate places in the valve body.
You do not have to remove the front cross member. - unbolt the motor mounts from the cross member.- remove the front sway bar.- jack the motor up in the front about 2" to 3".- put blocks of wood between the bottom of the motor mounts and the cross member. - unbolt the oil pan.- remove the oil pickup from the block; two bolts to remove and don't lose the O-ring or else you'll have no oil pressure after reassembly.- you should now be able to slide the oil pan forward and out.09quickly wrote:1) Oil pan gasket - In following the instructions for oil pan gasket replacement in the manual, it says to drop the front suspension cross member to get access to the pan. The motor mounts are on this cross member, not on the frame. Do I need to support the engine in some fashion before dropping this cross member on my head? Also, while I have the pan off, will the crankshaft seals be easily accessed to replace them at the same time as well? (Lying on my back with the car on jack stands, front only).
