1992 240 KA won't hold idle after comp. test...??..
revlis
Car: 1992 240sx HB
Ok so i just bought her a month or so ago and knew she would need work. I know the motor mounts are shot and other misc stuff. So anyway the comp. was a little down so i decided what the heck try the seafoam app sugested in the forums somewhere, smoked, sputtered spit then started running better that ever. Took a few rides around the block(no tag yet) more power and running like it should.
Problems started when i wanted to see if comp got better partially because i forgot to pull the fuel pump fuse the first time. Great test #'s 1=185 2=176 3=180 4=178 approx. So i put the plugs in(new ngk V power) hook the dist. wire/plug wires back up put fuse back in it place and start her up... Runs good for 10-15 sec then dies, restart give gas bogs bad and dies, I figure just needs fuel. Get more gas let the pump turn on and confirm its humming right two or three times still will only idle 10-15/bog w/gas. I go get a new Z32 fuel filter today(old one was nasty) still no dice. Help advice Thanx
-rev
sleepyS14
Car: 1997 Nissan 240SX 2JZ30DETT
2006 SAAB 9-2X AERO
MAFS or Intake hose popped off?
revlis
Car: 1992 240sx HB
sleepyS14 wrote:MAFS or Intake hose popped off?
checked maf connection seems fine all intake hoses fine. kinda lost lol
btw how do u put a pic as signature? thanx
revlis
Car: 1992 240sx HB
new info
so i tried to diag the problem some more and found out the motor will run(albeit rough) with the mafs unplugged, as soon as i plug it back in it will die within a few seconds. so i thought bad mafs took it out to check the elements, the whole thing is clean as new everything in working order. then i checked the mafs plug loom the jacket is split like there was someone it there messing around, three wires are intact but one is running to an engine ground on the plenum between runners 1 and 2...normal??
sleepyS14
2006 SAAB 9-2X AERO
honestly a bad MAFS cannot be seen with the naked eye. in my experience.. i had a MAFS that just went bad on it's own but obviously looked like everything was in working order. my friend told me to clean it. so i cleaned it with Mass Air Flow cleaner which is basically Brake Cleaner (that spray that dries of really fast) and that helped a bit but reallie didnt do much... went months trying to fix it.. replacing EGR solenoids and all that bs.. thing was clean as a whistle and showed absolutely no signs of anything wrong. then one day.. my friend was like.. here try mine (he had an S13 at the time too) .. sure enough we took his off..and plugged it into my car.. and WHAM.. brand new car!!.. it was amazing.. then i plugged mine into his car.. and WHAM.. dead. .. sputtered a few times then dead...
so my advice to you is this.. if you have any friends with an S13 MAFS around.. tell them to let you borrow it for 5 min. if you switch them out and all is well.. then problem solved.. you need a new MAFS.. (of course this is assuming you need a new MAFS)
or.. if you're interested.. i have a spare MAFS off a '92 s13 hatch KA24DE w/the pigtail still attached to it.. if you believe your wiring has gone bad. ive used this MAFS in my s13 and worked perfectly. this was actually the one i bought to replace mine in my 91 s13 before i got into my accident...
$60 Shipped. lmk if you're interested
btw. to put a pic on your sig.. the pic has to be hosted by a site.. in my case photobucket.com .. upload your pic there then where you would put your sig..
put [ I M G ](direct link to your picture)[ / I M G ]
be sure to remove all spaces !!
also sig sizes have to be at max 600x200.. so be sure to resize to email settings in photobucket
revlis
Car: 1992 240sx HB
yeah i though of that but no way to check, the import car enthusiast are harder to find where i live (one's that dont lie about "turbo-charged" lol).i appreciate the help and offer just to broke right now if my situation changes i'll most likely take you up on that. But i'm still curious if the kid who had her last swapped out the mafs from a different nissan(300zx?) and just did a ****ty job, do you or any one know how i could tell? picture perhaps. thanx again sleepy and good luck with car situation
sleepyS14
2006 SAAB 9-2X AERO
disregard the reallie shiny silver part.. thats the Short Ram Intake adapter..
but this is what it should look like..
this is the one from the '92 that i have for sale
