1991 Z32 Starting Issue
ali300
Car: 91 z32
Hi Z32 lovers,
I am new here. Owner of 91 Z32. I am having problem with my car. It starts for like 10 seconds then dies. I have spent almost 2 months to figure out what causes this. Here is my setup.
upgraded turbos and cams.
800cc fuel injectors
Upgarded fuel pump
adjustable FPR
Converted to AEM MAP Sensor 5 Bar
AEM EMS1
2.5" Exhaust System
Front mount intercooler w/piping
Nate_the_IV
Car: 1996 Nissan 300ZX
What are the symptoms? More details ='s better responses.
elecfus
you're also going to need to post your complete engine build, maps and running logs of all the sensors. the engine is modified and the ECU has been out of support for 3 years now. you can probably narrow down the problem in AEMlog yourself by just looking for a hunting sensor reading or solenoid.
a stock engine tends to be unable to run 800cc injectors reliably at idle and even if it does, you're exceeding the physical design limits of the engine unless you also rebuilt the lower end of the engine with better than stock pistons, rods, crank assembly.
what's the history of this car? how long ago did you buy it? how long have you owned it? do you race it? did someone else build it? what condition was it in, why did they sell it?
