1991 Z32 N/A 2+2 cranks but will not fire up!!!
[email protected]
Car: !991 Nissan 300zx Z32 vg30de 2+2
I turn the key and the car cranks but will not fire up. Changed 4 of 6 sparkplugs;Did try jumping the car. Got an engine swap to the same vg30de model was bogging alot.. and would die every once in awhile when it was idling like at a stopsign. Then when I was driving home it started to bog bad going upphill got it to the house and it shutoff... I have not a clue what might be the problem.. the brake booster is connected to the prvr solenoid connection closest to the brake booster on the engine... please this is killing me I need help.. thanks
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
You've verified that there is spark? Easiest way to check spark plugs and injectors is by taking the CAS off, having a friend slowly rotate it, and check the components manually. Spark plugs can be grounded to the plenum to check fire, and you can use a long screwdriver up to your ear to check the injectors firing. See if those are good, and report back.
(obviously check for these things with the key in "run")
Retro-Cow
Car: 1993 300zx TT
I had a problem similar to this.
The problem went away when I cleaned the connections on the Coolant Temp Sensor.
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Many bogging problems are caused by vacuum leaks, do you have anything deleted like EGR or AIV? And what do you mean about the brake booster connection? There should be a 90 degree brass port on the side of the intake by the balance tube.
