1991 Stock KA24DE Intermittent Bogging 900 RPM to 200 rpm sometimes seizing,WHY?
t3chnikqality
Hey all,
new to nico, but i'm on my third 240
1991 ka24de w/ 176,xxx miles 2.5" straight pipe w/ high flow cat
problem : I've changed the spark plugs, spark plug wires, o2 sensor, cleaned the injectors, sprayed the MAF and i just don't understand why the car keeps running rich and shooting out black smoke from time to time. At first it randomly bogs in the middle of driving like it's choking, but at other times it runs strong and perfect. it feels like it has bad air/fuel mixture. The other day i was driving on the freeway and all of a sudden my engine starts to seize, i gas it and nothing happens... randomly, it begins to sputter up again. now it's to the point where the idle jumps from 900 rpm's down to 200 and just chokes, if i gas it, all it does is seize. anyone know what's going on? i think it may be the vaccuum lines, or the fuel pump. any help is appreciated. i haven't taken it to a shop to get diagnostics but, i'm trying to figure this out on my own.
s13rb25det
Car: 92 240sx w/rb25det
check your knock sensor, Im pretty sure thats what it is.
t3chnikqality
battery connection was faulty. filed off most of the lime build up, and i sprayed MAF cleaner in the MAF sensor.
started up my car and it didnt bog down once. :D
t3chnikqality
thanks for the info rb25. i looked up some of the older posts regarding the knock sensor. seems like a b_tch to get out. if it gets worse, i'll check it out. but i sprayed the MAF and filed off the lime buildup on my battery connector and the car wasn't giving me any problems today.
s13rb25det
yeah cleaning the battery cables is a lot easier than changing the ks sensor. I hope you fixed it.
DALAZ_68
Car: 90' 240sx CA18det
i wish mine was as easy as cleaning things...
im down to 3 possibilities...TPS...fuel pump...KS
