pahrding wrote:I already checked out the manula before posting here. I could not find any reference to not going into Park, but there were references to not being able to get out of Park. At least I have the lesser of the two! I suspect that it is an electrical problem as opposed to something mechanical like the pawl. Anyway, the problem seems rare as nearly all the other problems I have had over the past 20 years I have had it seem common to others owners, I have always thought of the q as a sort of Japanese Jaguar and often suspect that the electrics were imported or designed by Lucas!
Now that you've checked the manula (whatever that is,) take a look at the manual...
Seriously, though, check out the linkage under the car. Undo the transmission shifter lever at the trans. Try moving the lever to park by hand. If it goes, inspect the linkage from the transmission to the shifter. If it doesn't go into park by hand w/ the linkage undone, you probably have a big problem...
