1991 Q45 Where do I go from here? FI Issues
silverqfortyfive
Great car when its running.
Got a set of eight used tested good from the site classifieds.
Was really cold last time I replaced the injectors and rushed neglecting to replace the o-rings.
Went about six months okay then with outside temp changes noticed fuel spilling.
Took the upper intake plenum off no biggie but now half of the injectors test bad one completely gone.
Tested the knock sensors looks like one is completely out.
Car has sit in the driveway for two years and I am missing it.
So what is the best way to go on replacing the injectors with something what will last.
I know this is a common problem.
Located in Camby, a couple miles SW of Indianapolis, IN.
Thanks.
Modified by silverqfortyfive at 9:52 AM 4/2/2010
Modified by silverqfortyfive at 9:53 AM 4/2/2010
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
ALWAY REPLACE THE O-RINGS!!!
What do the used injectors OHM at?
Where was the fuel spilling from?
How much do you want to invest in the car?
Does the fuel system hold pressure for more than 10 min?
You can replace EVERYTHING under there from $2K or do it the cheaper (riskier) way.
Q45tech
Define something that will last? I have 4 new oem installed that have lasted 22 months.
silverqfortyfive
Q45tech wrote:Define something that will last? I have 4 new oem installed that have lasted 22 months.
i am thinking like 120k miles
is there a budget way to convert to the '95 injectors
are these going to be better?
read a lot of threads but it is hard to tell what is opinion from fact
Thanks
Q45tech
Fuel injectors fail from exposure to E10 whether they are 90-93 or 94-96.
Nothing to be gained by changing design as long as you purchase brand new units.
With 20 year old cars you must get use to spending $2200-2500 per year [or do it your self labor]................that's just $200 per month in payments
Failure to spend $40-$50k in repairs since brand new means so very much is worn slap out. [multiple times].
We have a few 90-92 waiting for the owners to save enough for injector replacement same with transmissions. Those $3,000 hits are never saved for.
qship96
Car: 1996 Infiniti Q45
Fuel injectors fail from being subject to high under plenum heat loads over time......the cheap plastic bodies develop cracks.....then the fuel attacks them......ethanol is not the cause of the problem, heat is.....and the lack of proper heat MANAGEMENT........ kind of like the cheap plastic used for the knock sensors......heat eventually causes the plastic to become brittle and crack....poor engineering by nissan
Infinitiguy19
Q45tech wrote:We have a few 90-92 waiting for the owners to save enough for injector replacement same with transmissions. Those $3,000 hits are never saved for.
Why isn't it 1990-1993?
qship96 wrote:Fuel injectors fail from being subject to high under plenum heat loads over time......the cheap plastic bodies develop cracks.....then the fuel attacks them......ethanol is not the cause of the problem, heat is.....and the lack of proper heat MANAGEMENT........ kind of like the cheap plastic used for the knock sensors......heat eventually causes the plastic to become brittle and crack....poor engineering by nissan
I think Nissan had to strike a balance between long lasting and failing due to over heating, For Knock Sensors not sure about Fuel Injectors.
Q45tech
1993 is so rare because so few sold very short model year, kinda like the 1996................people waited until 94 and 97 came out.
1991 and 1994 were peak sales years.
silverqfortyfive
so i will just get the '95 injectors used, tested okay, rail and harness found for $120
do i have to splice the harness in?
something about grommets?
thanks
Infinitiguy19
Search Wes's posts!
silverqfortyfive
Paul Wall wrote:Search Wes's posts!
got it
zerothread?id=399119
searched "Q45 Forum / Cima Forum" & "Infiniti Online Mechanic" forums
for "injector or injectors" post body keyword
for even more
"Replace the lower spacers (stand-offs) that go between the runners and the fuel rail with two washers per bolt. That holds the updated rail into the runner port gaskets a little tighter." -Q451990
Modified by silverqfortyfive at 9:55 AM 4/2/2010
