1991 Q45 Cranking but Won't Run After Jump Start
oldschool45
Car: 1991 Q45
1991 Q45 Cranking but Won't Start After Jump Start
Q45 was starting and running great until wife left interior lights on and killed battery. Jump started, then after shut down car would crank but not fire. WHAT HAPPEND?Done so far-Checked all fuses Ran Mode 2 self diagnostic and got 34, 35 and 45Changed Fuel FilterFuel in oil when dipstick pulled
Did a lot of searching and couldn't find a similar failure to start episode.Bought a online Q45 Service Manual but still kind of lost on this one.
Please somebody tell me this is an easy fix and that I am just missing something electrical that happend when car was jumped.
New Q45 Owner
oldschool45
Car: 1991 Q45
Please Help!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
oldschool45 wrote:Fuel in oil when dipstick pulled
So you started it cold, shut it off, and it wouldn't restart? There is fuel in your crankcase?
You need to search better and read more. What you did was basically wash all the oil off the cylinder walls on the second cold restart so there was no compression. You will now have to change your oil and filter.
http://www.nicoclub.com/FSM/Q45/ for the FSM
TSB are at http://www.nissan-techinfo/infiniti/ for a one day subscription of $20
Search, read. learn and save lots of money and aggravation.
96Qowner
Car: 1996 Q45
How long did you run it after the successful jump start?
oldschool45
Car: 1991 Q45
maxnix wrote:So you started it cold, shut it off, and it wouldn't restart? There is fuel in your crankcase?
MAXNIXFirst of all thank you for responding!
Secondly, what a piece of crap this car must be if I can't start it up, run it for 5 minutes then shut it off. What the hell! I can do it with my explorer, Lexus GS400, BMW, whats so damn special about this car that you can't start it and shut it off.
Sorry about the mini rant but dude thats nutz!
oldschool45
Car: 1991 Q45
96Qowner wrote:How long did you run it after the successful jump start?
Thank you for responding - About 5 minutes.
Q45tech
Time is not the key, but coolant temp is as the ecu chokes the engine by simultaneous injection [flooding cylinders with fuel] if you don't allow a proper warm up.
Fully described in owners manual and FSM.Something dealers explained to every new Q buyer, or at least when it was towed in flooded.
Buying used without research [into quirks] often leaves OPERATORS flooded.
We still get a few flat beds in when owners flood Q usually the 3rd or 4th owners.
So few read the FSM\OM about HOW to shut off injectors in a second start----------------------floor accelerator and hold then turn the key to start and don't lift throttle until the engine revs up!
oldschool45
Car: 1991 Q45
Q45 TechThank you for the advice!
I will first read the OM/FSM Then Change my OilThen hold her to the floor till it starts
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
The main point is, start normally, but let it run up to operating temperature before operating or shutting off.
Victor
Car: 1994 Infiniti J30T
If what you posted is correct than this is the only car I ever heard of that requires special procedures if only run for a short period. It is definitely a design flaw and they should have had a recall to fix it. Unacceptable on such a high priced car.
qship96
Car: 1996 Infiniti Q45
Victor wrote:If what you posted is correct than this is the only car I ever heard of that requires special procedures if only run for a short period. It is definitely a design flaw and they should have had a recall to fix it. Unacceptable on such a high priced car.
I agree. Sell it and join the 240sx crowd
96Qowner
Car: 1996 Q45
I've certainly started mine and turned it off before it warmed up - no problem.
It's not common, but you're not the first to have flooding troubles after a quick start and shutdown - usually only a problem when switching cars in the driveway - 30 seconds - that sort of thing.
Let us know if that was it.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
It's all about how the injectors are progeammed to work on a cold start.
OBD I is stupid, remember.
oldschool45
Car: 1991 Q45
Thats why I drive this and she drives the Q
oldschool45
Car: 1991 Q45
This isn't my engine but can you say 700+ HP in a luxury sedan
Off topic but looks bad to the bone!
Q45tech
The Lexus V8 of the same 90-95 era used a 9th fuel injector to flood the plenum during cranking............. has its own set of troubles with today funky gasoline.
oldschool45
Car: 1991 Q45
Q45tech wrote:The Lexus V8 of the same 90-95 era used a 9th fuel injector to flood the plenum during cranking............. has its own set of troubles with today funky gasoline.
TechDon't jinx me bud! The GS400 has always ran like a top.
