1991 Q45 coil over shocks ?
richardyeary
Car: 92 Nissan President
hello all I am new to this
bad - a.s. system
other than looping A.S.fluid
what coil overs are you folks using on all 4s
factory wheel/tire
bad houston texas city streets
bumps/potholes etc.
factory height/smooth ride wanted
any help
thank you
BCC93QT
Car: 1990 Infiniti Q45
1995 Infiniti Q45
First off. Wow. The amount of scrolling I had to go through to find my login. 30+ year old car. Nothing available in USA. Blue springs.... will run you about 750 if u can find them. Got a set myself. Coilovers. Maybe 1500 to 2k. BBS wheels probably the best route.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
richardyeary wrote:
Sun Sep 18, 2022 9:48 pm
bad - a.s. system
factory wheel/tire
bumps/potholes etc.
any help
thank you
Houston Texas? Wow, you couldn't be closer to the original guru of the HG50 (PHG50) platform!
Look up Keith Bowers in Bellaire (Band B suspensions).
When sorted out, the active suspension Q is an amazing ride (not to mention a fine engineering achievement). As was stated, parts are hard to find, but Keith can point you in the right direction. It might be as simple as your strut accumulators needing a recharge of the pressurised gas. I personally use Argon now in place of the factory nitrogen.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
bad - a.s. system
and....specifically on this point: do NOT attempt to loopback until and unless you find someone that thoroughly knows these systems and how to do it properly. Yes, it's possible. But more people have destroyed their irreplaceable tandem active/power steering pump than not.
It is possible to do a full conversion to a passive system, but again--needs to be well thought out to do it properly.
If you do decide to de-activate your hydraulic suspension, keep the pieces completely clean (remove all dirt prior to breaking hydraulic lines). You can then re-sell them.
