1991 q45 broken timing chain on drivers side,need advice....
reyrey9350
Car: 1991 q45 and 2003 350z
1991 q45 dark green tan inside 15 inch bbs wheels live in madera california.need help... i just joined today i found the site thru yahoo ive had my q45 for about a month and a half. got it on a trade and cash for a samurai 1987.problem is i thought it was a crank sensor or cam and it turned out the driver side chain is broken and the oil pump chain too i took it apart most of it except the head got the exhaust mani off and the upper intake just the cams and head still bolted on i got a replacement head so no bent valves off another q in pick a park ready to go but i need to get off the right side plastic guide with the two bolts wich i cant the driver side head got the broken chain and bad valves the pass side is all good im going with the all plastic guide for now bcuz of cost i saw a picture here somewere about the timing marks but now i cant find it this is a common problem on these cars i read so far need help wit a picture on how it sits my email is [email protected] ill give u my cell if you can send me help tru the emails....thanks again.rey.yes ive done this kind of work before i hate it but like it too.im also a tow truck driver and autodetailer.automobiles and trucks are my passion,hobby,and work sometimes.
N/A Q45
Car: 94 Q45
If you have bent valves you might need a lot more then just a head.. Pistons could have cracks, holes in them, cylinder walls could be messed up pretty bad.
reyrey9350
doubt it.... either way ill know soon as the head comes off very soon.stripped the cam keeper bolts today
