Infinitiguy19 wrote:What about a issue with the speedometer?
InfinitiGuy with his inquisitive form of questioning/diagnosis may have stumbled on the problem. When the speed sensor is starting to die the speedometer doesn't work and the steering gets stiff. I'm not positive since I've never had the issue but I think the speed sensor is a component of the speedo cluster, could be mounted on the transmission though.obtuce wrote:.......And at times the Speedometer does not register. It is not always when the ACTSUS light is on but sometimes.
