1991 Pathfinder water Temp. sensor
gaylao
Car: 1991 Nissan Pathfinder
Anyone know where it is????
Pathfound49
Car: 2003 Nissan Pathfinder
2005 Volvo XC90
1999 Volvo S70
I can't say for sure, but my 91' Maxima, same engine as your truck, has the sensor and sender in the same location. It should be on the top, front of your motor. Directly above the water pump. I believe the single wire plug is for the temp. sender. The two wire plug is for the temp. sensor.
gaylao
Thank you so much for your reply.
