Zcar5 »
https://forums.nicoclub.com/zcar5-u309049.html
Mon Mar 20, 2023 2:09 pm
Thanks, I will check the coolant temp sensor and vacuum. The temp gauge seems to be working, but no numbers.
I replaced the vacuum hoses and tested some diaphragm and solenoid valves with a vacuum tester and manual.
I cleaned the throttle and used a fuel rail injector cleaner. I replaced several parts including fuel filter and hoses, spark plugs, pcv valve,
and IAC valve. Tachometer was intermittent. I checked the distributor connector and timing. Then I cleaned the ECU connector, reconnected it, and applied corrugated tubing to wiring harness on left behind plastic cover. The tach works. Odometer does not work, but the rest of the instruments work.
