1991 Nissan Stanza
NiSmo240luvR
Just wondering if suspension components from anyother Nissan will fit a StANZA? OR ANYTHING ELSE for that matter. also if nothing is compatible can u guys tell me who does make stuff for it? thanx guys
OneFastStanza
Car: '02 Nissan Sentra SE-R Spec V
'92 Nissan Stanza
'97 Nissan Maxim
'04 Saturn Vue Redline
'04 Ford F250
The only real suspension made per say for the Stanza is the Eibach Springs but they will wear out your stock dampers really quick.
Ground Control used to make a setup for the Stanza like I have on mine but the strut inserts for the front were discontinued by Tokico so they don't make them anymore.
And as for other compatible parts I think a couple of people have adapted Maxima components from similar years with some slight modification but I don't know the specifics cause I haven't had to do them.
EricZ103
Car: cars, duh
U13 altima front struts will work if you get, the dustboots and other associated stuff from a junked altima.With those struts you won't be able to use stanza spring though becuase they will be too narrow. What you can use are u11maxima, or j30 maixma, or u13 altima springs. This is all just up front.In back J30 maxima springs will fit.They make tokico rear strut inserts for the stanza along with kyb.Also intrax sells lowering springs for the stanza.
el_patron_94
Car: 1992 Nissan u12 Bluebird
does anyone know if i could do a s14 or an s15 conversion to my nissan stanza?
