tmorales509 »
https://forums.nicoclub.com/tmorales509-u51548.html
Sat Dec 02, 2006 7:53 pm
I have a 1991 nissan maxima gxe auto with 179,000. My problem is i was driving the car and turned it off, when i went to start it again, it wouldnt start. I kept trying & trying to start it and finally it started after about 8 tries but i had to keep my foot on the gas or it would die out. So the next day i decided to drive it anyways & everytime i come to a stop or its at idle i have to keep my foot on the gas or it will die, also i was driving on the freeway and the temp gauge warmed up to normal temp, then slowly started dropping until it got back down to cold, then it slowly started going back up. What could cause this with the weird temp movement? Also recently i've changed battery, spark plugs, fuel filter, air filter, maf sensor, engine control relay, fuel pump relay, dist. cap & rotor, timing belt & water pump,pcv valve,alternator, ive used fuel injector cleaner 3 times already, fuel pump does turn on. My guesses are sparkplug wires, thermostat or water temp sensor, those are the 3 things i havent changed since i had the car which is a little over 2 yrs & i dont think the previous owner changed em either.
