benre »
https://forums.nicoclub.com/benre-u160937.html
Wed May 19, 2010 9:05 pm
Sorry for being so critical. I have done quite a bit of work on many diff. cars. Just seems odd is all. I will add a little more than half a quart and go from there.
I have a lack of power in the my 97 2.4 4wd, and used to own a 94 2wd, the 2wd drove so much quicker. I changed my fuel filter and the downstream O2 sensor and it still has a lack of power. Already changed the air filter, plugs cap and rotor. I am wondering if I should just change the other O2 sensor, or is there are any spark plugs that you recommend. Or if I just expect too much from the 4wd. It just doesn't go from 50-70 very well. All the stuff i have done has improved the response but not enough.
Thanks!
