1991 Nissan 300zx not charging
300zxNA1991
Car: 1991 300zx
my 91 300zx alternator does not charge battery so i replaced both(battery and alter.) with new ones just to be safe. But same problem, only runs on what the battery has until it dies. Any ideas in what the problem might be??
aroche25
Car: 2007 Mazdaspeed 3 GT
Looking for a Z32 Slicktop
How is the alternator belt? It is tensioned properly? is it too worn to grab? I did the same thing about a year ago except I replaced the alternator twice and got a new battery before I realized it was the alternator belt that has just become so worn it was charging anything.
300zxNA1991
Car: 1991 300zx
aroche25 wrote:How is the alternator belt? It is tensioned properly? is it too worn to grab? I did the same thing about a year ago except I replaced the alternator twice and got a new battery before I realized it was the alternator belt that has just become so worn it was charging anything.
Alternator belt is band new, and it has been properly tensioned, i made sure everything has been done correctly but its still not charging
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
Make sure your connections to the alternator are connected and tight. If you forgot to plug in the connector, you would have the exact situation you have explained.
Next, where did you get your alternator? Autozone and Advance house brand alternators (worldwide mfg), are notorious for failure. You may want to have it tested.
Measure your voltage across the battery at 1500 rpm. If it isn't above 13.2v, you aren't charging properly. If it is, then turn on all of your accessories (lights, heater fan, radio, etc.) and measure again at 1500 rpm. It should stay at or above 13.2 v.
300zxNA1991
Car: 1991 300zx
marty1mc wrote:Make sure your connections to the alternator are connected and tight. If you forgot to plug in the connector, you would have the exact situation you have explained.
Yes I have made sure every thing is connected correctly several times, and still not charging right. My alternator is a nissan reman from courtesyparts.com (which they have a location near me), and had it checked and replaced twice just to be safe. But it still doesn't charge the battery. Is their any other connector or fuse else where that could be bad and not let the alternator charge?
marty1mc
Here is the wiring diagram. There is a 10A fuse in the circuit, fuse #10 (shown on diagram). Check that, if it's good, then check for +12v on the w/r wire on the plug connector. If it has +12v, then check ground. I would expect either the fuse is missing/blown or you have pushed a pin out somewhere when trying to connect everything.
http://www.300zx.co.uk/cgi-bin/manual.c ... &total=133
