evol.m30 »
https://forums.nicoclub.com/evol-m30-u85400.html
Sat Jan 05, 2008 1:59 pm
New plugs, wires, cap and rotor button. Still has the problem. The car seems to be going into its safe mode around 2,000rpm at times. When it is having its sputtering fit, it now dies and is getting worse. When I disconnected the MAF sensor it just went to normal safe mode and would idle and run to 2,000rpm. When I plug the MAF back in it starts sputtering again.
MAF sensor? Is this a common problem?
I checked the fuel pressure.. it was fine and it has a new fuel filter.
Engine also runs fine till 2,000rpms in safe mode, I wouldn't think that a bad fuel injector would let it do this.
