1991 Ka24e Hardbody Problem
Dsm-4-Life
Car: DSM DUH!
I recently rebuilt the engine but I didn't take it out, I had someone else do that for me...
I put it all together and now the truck runs like a dog, and it idles fine, what could be wrong with it? The compression is all in the 130+, it has new Oxygen Sensors, Plugs, and Wires....Thanks!
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Any idiot lights on?
Does it act like fuel delivery? Maybe a clogged filter or a dying fuel pump?
MAF sensor?
houdini
Car: 1993 Nissan 240SX Convertable
2001 Nissan Frontier CC
can you better define "runs like a dog"?
Dsm-4-Life
Car: DSM DUH!
Desert Rat wrote:Any idiot lights on?
MAF sensor?
I changed the filter, its not throwing any codes, I'm going to try cleaning the maf, is there any other way to test the maf without buying a new one?
I don't think 91's came with mafs I'll have to look
Modified by Dsm-4-Life at 10:32 PM 7/9/2007
NM50
Car: 94 D21,98 03 hummer H2,66 311 CA18ET ROADSTER,94GEO METRO pimp mobile
CHECK YOUR CAM TIMING. THE MAF IS PART OF THE THROTTLE CHAMBER.ITS ONLY AVAILABLE AS THE VENTURI ASSY.
mexicana
Car: 1991 D21 Hradbody
alright first check the timming if the maf was bad the mil would light(MALFUNTION INDACATER LAMP AKA Idiot IGHT) Check for clogged fuel strane in the tank i had that happen to me pain in the rear hope this helps
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
It idles ok...but has no power.
1. It could be the distributor. The timing advance isn't functioning. Idle will work but it has no power once the rpms come up.2. A clog or restriction somewhere in the exhaust system. 3. Weak Fuel pump,clogged fuel filters. (There should be 2. One at the tank and another inline somwhere under the hood). A weak fuel pump can't deliver enough volume so the engine gets fuel starved. Same effect when fuel filters are clogged. ( yes I know you changed it, but these kinda issues are good reference for others )
onejake
Car: 1995 240sx se
I will bet on this one!!!!
onejake
Car: 1995 240sx se
Timing it is!!!
