slipnfall »
https://forums.nicoclub.com/slipnfall-u4227.html
Mon Mar 14, 2005 8:25 pm
The FSM lists two lift bracket attachment points. Both are near the top of the head:one is passenger-side, towards the front, pointing to the side. There are two bolt holes, like 1" apart. The other two are on the D/S, towards the rear, again pointing outward. Two holes there also. At least one has a ground strap attached normally. You can spot them pretty easily.
I'v used ^^^'s method more than once, it works faily well. Just watch the chain doesn't slide and bust your injector caps. On my last DE install, we used a single bolt through the above mentioned lift point, and attached the other chain w/the P/S pump bracket bolt.
I'v never pulled transmission w/engine, so I can't vouch on how well it would hold with the added weight.
HTH.
