JNM240 wrote:On the SOHC KA only (I have no personal experience with much else....):
The distributor can only mate to the oil pump shaft (hence 'go in') one way. HOWEVER it is entirely possible to have the oil pump one tooth or more off from the crank gear, thereby throwing the entire timing off. Look for the half moon shape at the bottom of the distributor shaft, this is what mates to the oil pump.
If the DOHC is similar, than you now know what to lookData for.
Thanks man, I couldn't think of the name "shaft". It was a long day of database programming. uhh... those days suck. But that is how my lady's sentra is too. that is how I thought it would be.
Here is where I am at now...I did a tune up, wires, plugs, cap, rotor, and new starter too.
I am getting backfire through the intake and if I dont have a intake pipe on, then flame (small 6-8 inches) shoots out the throttle body.
The car sounds like it wants to start moreso when I am either modulating the gas pedal or full wide open throttle start attempts.
Like I said before....I got this from a foo. and not a too wong kind, but I guess either kind of foo isn't good.
Lataz
Thanks
Dustin
