RatedR »
https://forums.nicoclub.com/ratedr-u4104.html
Sun Apr 10, 2005 11:06 am
Got the 12V reading from the 1st connection, no reading from the others. I looked at the harnesses given from AllData and found a connection near the fender around the washer fluid reservior. Tried fixing that, no good. Read ECU codes, threw 12, MAF circuit. Tried replacing ECU and read codes. The new ECU threw 11 and 13, crank sensor and coolant temp. Replaced coolant temp, now the ECU reads 55 which is all good. Still limiting revs to 5K, dont know whats wrong now. I'm thinking when I tried disconnecting the 4th gear sensor on the old ECU, it didnt matter. Now on the new ECU, would it be apparent that the 4th gear sensor is the problem?
