rabalam »
https://forums.nicoclub.com/rabalam-u198021.html
Sun Jun 10, 2012 6:26 am
Sometime soon after retrofitting my Q45 with new coolant, the expansion ac valve failed. That is, the AC is cooling fine, but the valve is stuck open (or closed) so that only heat comes the vents.
My repairman can't say definitively whether or not the new coolant has anything to do with the valve failure.
Can anyone of you guys answer that question?
Also, I understand that replacing the valve requires that a substantial amount of the dash has to be removed. The factory installed it between the firewall and blower motor housing. Is that in fact the location of the AC expansion valve?
Thanks Much!
1991 Q45 180K miles
