1991 Infiniti Q45 BNR32 front brake upgrade?
Mikey_ZX
Car: 91 Infiniti Q45 1st Gear Start
94 Nissan 300zx N/A
2008 Chevy Aveo 5
2013 Toyota Venza Limited AWD
Hello, I have a set of Nissan Skyline BNR32 front brake calipers and rotors, wanted to know if these bolt directly onto my 1991 Q45 or I need some type of modifications to make it work. I think the rotors from the R32 are thicker and I haven't tried installing them on my car yet. Just wanted to hear some feedback or suggestions from any members that have installed this set of front brakes on their 91-96 Infiniti Q45? Thank you for your time!
SanCarlosQ45
Car: 1994 Q45 144,000
2013 Nissan Xterra Pro-4x
1967 MGB GT Special
I have a full set of R32 gtr brakes on my 94. The only modifications are to remove the dust shields from the front or at least modify them for the larger calipers. Other wise they are bolt on other than the other thing is you will need different soft brake lines; I used S13 to Z32 conversion lines which can be found anywhere. I don't like them that much though as they don't mount up very well.
I would recommend you change out the rear calipers with either r32 or z32 300zx calipers as your pedal might feel a bit mushy with the change in piston sizes without the full set. With the full set the brakes are fantastic and they use 300zx z32 pads so selection is quite good.
Mikey_ZX
94 Nissan 300zx N/A
2008 Chevy Aveo 5
Thank you for replying and giving me the information that I needed!
cbird805
Car: 2003 Infiniti M45
1995 Infiniti Q45 Base
(prev) 1994 Infiniti Q45 Base
The Z32 TT brakes are the better brakes.
91q45t
Car: 1991 Infiniti Q45T
I have a set of z32 running bigger rotors on my 92. She stops on a dime!
