1991 hardbody not getting fire from dist.
spyder77webb
i have fire goin in to dist and coming out of coil but no fire from dist ive change cap button and ign mod
longtooth
Car: 89 d21 HB
If you have spark going in and you replaced you dist cap and rotor and the spark is still not being delivered to the ignition cables.
I would remove the distributor cap and have a buddy crank the engine while you watch the rotor to make sure it is spinning.
spyder77webb
it is turing i dunno what to check next ive checked and changed everything i know
longtooth
Car: 89 d21 HB
Well I would try a different cap and rotor. If your getting spark from your coil and its going to the cap then I would say that the cap and rotor are to blame.
