1991 G20 Driverside window slow operating - Bad Motor? How to remove doorpanel?
rkh58
my driverside window is slow going up and down. Sometimes I have to help it by hand to get it to move or to close all the way. What could be causing this problem. Bad motor or something else?? Also how do you remove the door panel without screwing it up??
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
My guess that either the motor or regulator is going... I would personally go ahead and get a window regulator assy (I think they may come with the motor?) to hav eit ready.. It will eventually break and most likely the window will fall down inside the door.....
IM also moving this to the G20 forum..
gregorio
Car: 87 200sx es, 92m30
try cleaning the glass w/WD-40,use a rag soaked in wd-40 wrapped around a flat blade or metal nailfile to clean the glass inside the door on the outside--this also cleans the wiper seal. Also use the wd-40 to clean inside the vertical channels that the glass slides up & down in.
