1991 D21 V6 Crankshaft Bolt
KB Services
Help please changing the water pump and I need to remove the lower pulley. What size is the socket to fit the crankshaft bolt. Socket size not bolt size.
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
I seem to recall that it's either a 24mm or 26mm bolt....I am not 100% sure on that.
don't use an imperial socket or you'll strip the head and be really hosed.
