Check the cables and connections. There are a few ground straps going from the engine/transmission assembly to the body. One goes from the back of the head to the firewall, there is another one from the starter mounting bolt to the under side of the floor pan, and I think there is a third one farther back still. If there is a fourth, I have not found it, but I know that these are often overlooked on probably every car.Desert Rat wrote:if you're still having this issue, what condition are your cables in? If they have a lot of corrosion / crud, they might not be transferring enough juice to start the truck.
